Laser Classes for July 8-10
The Laser Basics was the only class we offered. it is about 45-60 min class. It covers how lasers work, what materials work for cutting, etching, and raster. We then spend about 15-25min on each laser, depending on the questions. In that walk thru, we demonstrate how to place and secure your material, the file formats, the software, how to home & set a new home/origin/offset, how to check if the material fits your cut (frame/bounding box), and much more.
For those that already took the Basics and understand how not to set the building on fire, the differences between Vector and Raster, and are comfortable using a laser, we offer the Epilog Zing & Thunder training. We spend 20-30 minutes on each. We do go a little more in depth on each, as folks tend to try a few things and ask more questions. so the class goes about 60-120 minutes.
All the classes are now on the calendar. Below are the registration links. Soon, we will have a new calendar process, and it should be a lot easier to post classes requiring registration.
Epilog Zing & Thunder Certification
Learn to use the new Epilog Zing & Thunder laser! We meet at the lasers in the workshop.
This class is for members that have already taken the Laser Basics, and are checked out on the old lasers.
There is a hard limit of 8 students per class. Students must be a member of the MakerSpace.
Friday noon Epilog & Thunder
Friday 6pm Epilog & Thunder
Sat 1pm Epilog and Thunder
Laser Basics+LaserSaur, Epilog, & Thunder!
Host: john a. gorman Contact: [email protected]
Learn to use all our lasers! The LaserSaur! The Thunder! And the Epilog Zing! We will spend 45-60 minutes talking about lasers work, about the file types for vectors and rastering, what materials you can engrave, raster, and cut. Then we walk thru each machine.
Friday 7:30pm
Saturday 7pm
Sunday 1pm
Please, Register for only one class. I had someone register for 4 classes last time. that was 3 people not able to take the class. this is different from the wait list.
Thank you
Thanks for the class!
If I read the Meetup schedule correctly, and IF you’re already a user of the “old” lasers, there appears to be another seat available at today’s 1:00 class; Laser Certification: Epilog & Thunder.
