Hi, this is a great question, was curious too,
sent a question to Bullseye, here is their response
(just noting that we go to above 2000 degrees in our final firing for ceramics):
This is Paul at Kiln Frog.
Typically, kiln wash for ceramic work is different from kiln wash for glass fusing work. I have a kiln that I do both in and I have a set of shelves that I use my glass primer on for my glass projects and another set of shelves that I use a heavy duty ceramic kiln wash on that I use when firing my clay projects.
Shelf primer or kiln wash for ceramic work is much coarser than glass shelf primer and is rated to withstand temperatures up to 2350º F.
Bullseye does not list a temperature range for their shelf primer, but they do recommend scraping and rewashing shelves any time the shelf is subjected to temperature above 1300º F.
Best,
Paul
On Fri, May 19, 2023 at 10:28 AM
Hello bullseye,
I use this kiln wash for glass, my question is can I also use it for my cone 5-6 ceramics stoneware kiln? What cone or temperature is this rated for?
Thank you
