Kapex Miter saw is not working correctly.
Laser turns on, relay clicks/ fires, but the blade does not turn.
I’m not seeing an independent fuse on the motor online.
Anyone want to tackle this? @Team_Woodshop
Hey Ian. I was looking up the symptoms online trying to see if I could figure out the problem with it and the most common answer was a burnt out motor. The kapex seems to be known for that. Supposedly the motor goes bad before the brushes even do. Hopefully the problem is smaller than that. Either way I think it needs to be sent back to festool. Mike Jury is familiar with this process. Do you know if we still have the box? Thanks. P.S. - Supposedly festool tells customers that having the wrong amperage can lead to motor failure. I don’t know if that applies here, but the receptacle it was plugged into looks a little suspect. I took a picture of it.
I’m no expert, but we should probably replace that outlet.
I don’t know if we have a box.
Let’s send it out for repair. I’m not sure what supplies we have so I couldn’t fill out the return form.
@Andy if you want to fill it out and get it sent out, here’s the form. https://service.festoolusa.com/account/repair/
You can put my email and phone if you don’t want them contacting you.
[email protected]
We should still have the box. The last time it went out for repair when it came back I unpacked it and the previous woodshop chair said he was saving it. It should be on the top shelf where the cutting and bread boards are stacked.
Nah…just put one of them child proof thingy in / over the charred one and keep using the rest.
Or…got blu tape?
Where at DMS is this electrical outlet located so it can get replaced.
Who filed the repair order? I’ll forward the email with packing instructions
I got it packed up with the help of @jeffhess .
I followed the packing instructions on the festool owners group forum. It’s ready to go. It just needs the label printed and to be dropped off at a ups I believe. I’ll leave it in the box in the woodshop unless instructed to do otherwise.
What’s your email? I’ll send you the label
Thanx. I’ll replace that outlet on Monday when I come in.
