Running into an issue with the joiner. I was trying to run some 4x4 stock and the joiner is not running square. It’s putting an angle across the wood and also causing a taper from the front of the stock downwards to the back. See picture.
I made sure the fence is square but it’s still causing the issue. Is there something I’m missing or is the joiner having a problem right now?
I
