OK, so looking for suggestions here. Putting up a couple of walls of nickel gap tongue and groove, where I need the tongue to be about a quarter inch longer than the groove is deep, in order to create a nice offset looking joint.
Been cruising my favorite sites and whatnot, but am not seeing any ideas on whether anyone makes router bits with the same dimensions OTHER than length of the tongue. I suppose I could just set the fence so that the depth keeps the wood from engaging the bearing when cutting the groove, but didn’t know if anyone had a better idea or an adjustable diameter groove cutter, or a groove cutter that I can put a bigger bearing on, etc.
And on a related note, does anyone know if our router is again multi-speed, or is it still stuck in turbo? I’m doing this in mahogany, but will want to dimension down some hard maple while I’m up at the shop.
