**Please tell him that I referred you.
A national staffing firm and are currently seeking a (an) Test Technician for a prominent client of ours. This position will be located in Dallas, TX. Details for the positions are as follows:
JOB DESCRIPTION:
Responsible for implementing and maintaining the effectiveness of the quality system Applies a high level of technical support in a specialized discipline using knowledge and theory of electronics, life science, chemistry, mechanics, software, etc. Understands and uses knowledge of other disciplines. Test Specification - Drawings. Uses computer applications as needed for functional specialty. Advanced skills in computer hardware and /or software applications. Accepts non-routine and complex assignments. Follows established procedures Uses judgment and makes choices on how to proceed. Assignments often require creativity. Researches, recommends, and implements appropriate changes for process improvements. Uses information from within and/or outside the organization when necessary. Reads, understands and instructs others in the use of manuals, test procedures, and documentation associated with specialized equipment. Reads, interprets, and may create engineering drawings, schematics and complex test procedures. Writes basic procedures and technical documents. Working knowledge and use of complex tools and equipment specific to functional areas. May use statistical, mathematical and other quantitative and qualitative methods and measurements. May create tools and fixtures specific to functional area. May work closely with engineers to execute product design. Constructs complex engineering prototypes, models and builds special test equipment. May perform testing on prototype electrical and/or mechanical designs. Conducts complex testing, analysis and troubleshooting. Conducts testing to determine effectiveness of product specifications. Complies to all safety standards and regulatory requirements. Degree of physical effort and environment: Normal work fatigue. Normally safe environment. Typical electronic manufacturing/laboratory/office environment. Some work subject to frequent hand/eye coordination, lifting/carrying of objects or operating equipment.
If you are interested in hearing more about the position please respond to this email with your resume attached or contact me at (813) 321-6403.
