Hi, went to use the laguna band saw and noticed that the e-stop is loose/non functional. Seems like the threaded collar that the knob assembly threads into may be broken or stripped.
If you see this before you leave… power down the machine and check if the threaded ring on the inside of the switch assembly has come loose? It has a history of working it’s way off.
