I probably overwrote the 1/2" steel config on Plasmacam. You have my sincere apologies.
A couple of the Path Conversion parameters had been changed and caused a bit of problem for the class on Monday night. I was trying to define a config for the class to avoid this.
There has previously been talk of allowing our own configs. There is a settings.cfg file in the Plasmacam directory. When I did a save, its timestamp was updated. Notepad shows that it includes the readable names of the configs as well as many non ASCII bytes. Is it feasible to allow each person to supply their own? What happens if this file is not found? Would the application supply the real defaults? There are several things I would like to try but I don’t maintain this so I will just throw out the questions?
