ISSUE or REQUEST: issue
Affected Tool or Resource: Cold Cut Saw
Committee, Group or Volunteer who usually handles this type of ISSUE or REQUEST (Please tag using the @ symbol. A list of current groups that can be “mentioned” is maintained at this LINK.): @Team_Machine_Shop
Details of ISSUE or REQUEST (Please be as specific as possible):
Cold Cut Saw Blade is broken, and the saw is unusable till it is replaced
It broke when I was cutting a piece off the end of a 1"x3/16" flat stock with out it being clamped in both sides of the vice. I was shown how to do this when i was trained but it bent the smaller stock. I would be happy to replace the blade, I found some but not one the exact same type, so if someone tells me which to use I’ll change it. I can also pay for the cost of the blade if I need too. I recommend we add a minimum size for cutting stock when it isn’t clamped on both sides to the class teaching.
PLEASE REMEMBER DALLAS MAKERSPACE IS AN ALL VOLUNTARY RUN COMMUNITY.
Our volunteers will handle the reported issues as quickly as possible; however, there is no guaranteed time frame for resolution - due to the voluntary nature of how things work around here.
Please consider volunteering to help maintain some of our resources to help keep things running as smooth as possible here! Thanks!
If you are reporting or resolving an equipment issue, please also update the tool status board appropriately.
NOTE: This category is NOT for discussion threads. Any “discussion” will be split out by one of the TALK Moderators to create a separate “discussion thread”.
