Hello, I hope this is in the right place. Last night I was using the Bridgeport and the power drawbar did not sound as strong as it usually does. Regardless, it still pulled the tool in and seemed fine. I was getting some help from others in the space as it didn’t seem to be cutting right 30-60 minutes later, and the cutter began coming out of the taper. Later I noticed some metal buildup/scarring on the top of the taper, I’m not sure if it was there when I started or not.
The shell cutter in question is in the tool cabinet nearest the Bridgeport and has a red “Out of Service” tag on it.
I later tried using the other shell mill and had no issues for the rest of the evening.
