Hi all,
I’d like to make some ink stamps using the laser and need advice on which material to use, what thickness works well, and where I can get said material. Thanks for the help.
Hi all,
Last time I asked I was told this-
you’ll have to glue to a backer, probably wood.
Those are your 2 choices from all I have seen. I would go with the Johnson’s.
The stuff from Johnson Plastics is the same stuff from the now defunct Laserbits.
It works pretty well and while not totally odorless, is a good improvement over the old stuff.
Thanks all, that’s exactly what I needed.
FYI, LaserBits is defunct now because Rowmark bought them and is selling the parts and peices they like through Johnson Plastics now.
