Is there a gram accurate scale at the space? Maybe in science?
probably also in 3d fab for weighing out the filiment.
Probably can’t take it from there, but sure you can weigh what you need.
I’m mixing powders outdoors for ceramic glazes so that won’t work. I’m trying to avoid going back home where I left mine.
Try Creative Arts. I believe they have one for resin.
If you’re taking out of the CA area, best to leave a note with your name and phone (and obviously, return it )
I’ve used a scale from Science in the past but not since they moved so I can’t direct you specifically to a location. But they do have one. I second Marlow’s leave a note while sneaking off with illicit goods tip.
They have like 4 in science and one in CA.
Bumping this back to the top to see if these are still the best options for a scale. Pinewood derby time and my son and I will be maxing out the 5oz limit tonight
Pretty much. 3D Fab has a scale for weighing things. Nice electronic one. Ceramics has a mechanical scale. Probably science and CA still have theirs…
