I am happy to try to fix it, but don’t want to mess with it if there was already a plan.
Let me know.
Let me know.
It got turned on its side so oil got into the line… it’s probably fine to use after a few months of sitting upright, but if you want to poke around and make sure there’s no oil where it shouldn’t be, probably go for it? Otherwise it should function.
I would love for you to look at it if you have time. I did try turning on recently and it didn’t work, the larger one was also making terrible noises if I am recalling correctly which one had which issue.
What’s wrong with the pumps?
One got tipped on its side a while back and the oil leaked up into the tubing, I got the oil to drain from the tube but it still didn’t seem to be working when I tried it.
The larger one I am not certain what happened but it was making noises that I feel certain it shouldn’t be making.
I’ll take a look at them too.
Thank you so much more than I can express!
I tested them both this evening, both seem to be running well. Will give them a longer test next time I am up there to make sure all is good.
