Soldering vs brazing is, I think a matter of historical usage more than definition. Though I tend to think of soldering as filler that could successfully be applied with propane air torches. Things that require at minimum Acetylene air or MAPP air seem to be on the fence, soldering or brazing depending on the particular trade. And things that require oxygen are pretty much always brazing, until you start melting the base metal.
Don’t get me started on the trade with a certain subset that seems to think that just because you are using the smallest refillable O/A bottles, what you are doing is welding. Let me see you melt that copper and use an extremely high copper alloy, or pure copper filler, then you will get my respect for your welding skills. But you most likely won’t be doing that on 3/4 copper pipe with that setup.
I will also note that country and language seems to make a difference. Chinese soldering (normal 60/40 or lead free) seems to always translate to welding when translated to English.
