Thanks to Lloyd Plum (Plano Mill) for some interesting wood – I was looking for some pecan – he didn’t have exactly what I was looking for in stock – so he threw a pecan log on his mill and cut me two slices, took less than 10 minutes!
Tom, I cut them in to 1"-2" strips and then laminate them with bandsaw blades I’ve cut into 6" strips and make damascus steel and make knife blades, or I cut knife shapes from them and then heat treat, handle and then sharpen them into knives.
Most of the bandsaw blade material is either 15N20 or L6. (Mostly 15N20 since L6 is usually for the much larger bandsaw blades like those used in a sawmill) The circular saw blades are usually some vairant of high carbon steel like 1095, 1075 or 80CrV2.
In any case I’ve cut them on either the cut off saw in blacksmithing or the bandsaw in the machine shop. I’m going to cut them on the plasma cutter in the metal shop next.
Those are actually the very best. 12" gives a lot of surface area and the not so thin kerp provides ample opportunity to put on a nice beveled edges like a hollow ground edge.
Thanks for thinking of me. I’ll take all that you want to give.
