I need to install some simple (i.e., non-swaged) pin and barrel hinges. They will be installed on the outside of the (miniature) door and its frame. I will mortise both leaves flush into the door/frame. I know that in theory there should be a small gap between the door and its frame. How do I determine roughly how large that gap should be?
Thanks in advance for the advice.
(Before you try to convince me to install them like “normal” butt hinges inside the frame, the realities of scale prevent that. My door/frame are each 1/16" thick and my hinges are slightly larger than that.)
