Hello!
First time using the laser cutter and I’m having a lot of inconsistent cuts. The forum doesn’t let me post images, but each of these should be an identical copy of one another. However, there are differences between .5 mm to 1 mm. I ran the blitzen laser on 20 mm/s on 55%. There are also some scorch marks, so I’ll try it at a higher speed/lower power in the future.
I focused the laser using autofocus and sticking a piece of masking tape on my material as it is a bit transparent.
I’m really not too sure where I am going wrong here and am trying to problem solve. Does anyone have any suggestions? I’m pretty new to this so I’m not sure where I went wrong or if a mm or 2 of error is normal for this laser cutter.
