Hello DMS Potters,
Thank goodness there are not very many items that have expired. I did notice several projects are expiring in the next few days, so please come check your items.
Remember to label your pieces with your name and the date you placed it on the shelves. Each ware board should have a label. Sometimes items are moved away from each other and if it becomes separated from your group, it just looks like an unlabeled project.
When you place items on the shelves, try to set a reminder or appointment in your phone of when you should come back to DMS to check your project.
THIS POST IS NOTIFICATION THAT THE ITEMS SHOWN HAVE BEEN DISCARDED.
REMINDER
We allow 30 days for your clay item to be on the In-Progress Shelves.
**TIME LIMITS IN CERAMICS DEPARTMENT**
ITEMS ON BATS is 7 DAYS
Please return within 7 days to move your item from the bat to a board.
If a project is on DMS bats after 7 days, we will attempt to wire off your project and place on a ware board.
ADDITIONAL RULES IN THE CERAMICS SPACE
- If you have a glaze that will run, please provide your own cookie before it goes in the kiln.
- If you have not allowed an unglazed bottom and a bottom edge of 1/4", please provide your own cookie.
- Bisqueware should not be stored on In-Progress shelves. If noted, it will be discarded you will have 7 days to remove it before it is discarded.
- If your project contains added items, like copper, toothpicks, or newspaper…the piece won’t be fired unless these items are removed. Basically, anything that might cause damage to or influence other pieces in the kiln will likely not be fired. Generally, these items are placed on the NEEDS ATTENTION shelf with a note.
- If you haven’t seen your item come out of the kiln, please check the NEEDS ATTENTION shelf near the kilns and check the Ceramics Kiln News thread.
