Has anyone tried to import a SVG file from inkscape to easel. I keep getting a message the file won’t be accepted because of imbeded paths or noise etc. The solution easel offered is below. I tried different svg file formats from inkscape and different path commands but to no avail. Has anyone faced this problem? Any help would be appreciated. I even tried to import into vcare. But that didn’t offer the file format svg of dxf files.
SVG Import Guide
Easel supports only certain SVG files that can be imported. Here are some common hiccups that you might encounter and some suggestions on how to fix them:
Importing Text
Due to variations in fonts, Easel does not currently support importing SVG text elements. However, you can still import your custom text with a custom font, you just need to follow these steps:
- Adobe Illustrator Select all objects and select Object -> Expand
- Inkscape Select all objects and use the keyboard command Ctrl+Shift+C
- Corel Draw In the SVG Export dialog, in the section called “Export Text” make sure “As Curves” is the selected option (not “As Text”). Thanks to forum user ChetKloss for this tip.
- Other programs You need to convert your text into paths, which means making it un-editable as text. If there is an equivalent to ‘Create Outlines’ or ‘Expand’, that is what you are looking for.
Import
Embedded images
Although SVG is a vector format, it actually allows embedding images that are not vectors. Easel cannot process these images, and they’ll have to be removed.
Import
Converted DXF files
If you are converting a DXF file from a CAD program to an SVG, there can often be some issues with paths not being joined together properly. If your file is importing as a series of disjoint paths, rather than a single object, this might be the cause. In order to solve this problem, you’ll have to join the individual line segments. This is usually done by selecting all the objects and running a “Join” or “Weld” command (depending on the editor).
Import
Complex files
If you are using an SVG traced from an image, try to simplify the file as much as possible before importing it. Traced images often contain many unneeded paths that can choke up Easel, including white filled background paths and extremely small noise paths that aren’t desired. It is much easier to simplify this SVG in your vector editor before bringing it into Easel.
