I'll be Looking for You
This is a corner clamp, use to hold/clamp two pieces in a right angle for glue-up or other types of right angle joining:
This is it’s mate, somehow now in three pieces and fairly useless:
Note the clean edges…this was cut, not snapped or whatever:
It was found under the table at the window in the Woodshop Annex (@Team_Woodshop) in generally plain view of the cameras,so I’ll be looking for you…if you come forward with explanation as to how this happened, or simply replace the item, OK. Otherwise, you probably won’t be having a good day…
could we maybe 3d print a new one?
not the one who did it- not justifying it… just looking for solutions
This is the replacement cost at Rockler: https://www.rockler.com/clamp-it-assembly-square
$12.99
13 and some change… bah. I could just order that tonight and donate it to woodshop.
That’s very much appreciated, but I believe the real problem is something more insidious: that people are knowingly damaging equipment and instead of owning the mistake, they just drop the broken tools back in place and walk away.
Agreed that is an issue, one may be able to review the camera footage and proceed from there.
Either way I can only help where I have the capacity to do so thus I’ll get the order in after work.
edit:
Looks like its on amazon. I can get that taken care of now.
Right…the $ cost is immaterial in this case…a red herring. For a member that would do this, though, what wouldn’t they do?
Order placed and on its way to the space.
https://smile.amazon.com/progress-tracker/package/ref=ppx_od_dt_b_track_package?_encoding=UTF8&itemId=kjqgsroutiktwn&orderId=111-0112285-3153835&vt=ORDER_DETAILS
Should be there between the 10-15th
Not stirring the pot here or suggesting that its best for DMS. Just things like this reminded one that there are some membership based groups and “lodges” that have a professional background check service on speed dial for when a new member signs up.
Sigh…I wish we had eight altogether. :wink:
I have never known of a background check for disrespect…
This is intentional destruction of DMS property, and will be dealt with as such. This is also a good example of why we can’t have nice things. I am very disappointed in whoever thought that this was ok. This tool is now useless to those that know how to use it property, not to mention the fact that the set of 4 is now incomplete. It would have been just as easy to make something similar out of a scrap of wood.
IMHO, this ranks up with the person who cut the tab off of the box-joint jig, rendering it useless for that purpose until someone else came along to fix it.
Modifying DMS tooling to expedite your own project isn’t OK: it may save you a little time, but it creates a larger inconvenience for someone else to identify and correct the problem.
Not excellent.
Credit Checks are a better measure of responsibility. However, a lot of a$$#0les have great credit.
Hey…words can hurt, man!
:slight_smile:
You’re just upset that I successfully made it past the epithet police. :grin:
