This is not an angry diatribe, just a wish for more excellence towards one another. (And there are those of you who this post will not apply to at all because you already ‘get it.’)
If you go into any shop area - machine shop, 3d printing, CA, Automotive, Jewelry, etc., users seem to respect the space and the person who will use it next. Tools are put back and messes are cleaned up. Not so the woodshop. For instance, if you make just one or two cuts, it takes just one or two sweeps of a brush to clean off the machine. If you are running a lot of stock, it takes 2 extra minutes to check the dust collector before you begin and only 10 more to empty it. Tool storage is a problem, but instead of adding to a pile, how about taking a few minutes and organizing a shelf. If you do a bunch of sanding with the power sanders, how long would it take you to put the used discs in a stack and vacuum the table off? My enjoyment of the space decreases, as does the pleasure of doing actual work decreases exponentially when I walk in and see trash everywhere.
I’m not perfect - even if I clean up 9 times out of 10, I’ve certainly been guilty of making that 1 cut, then walking away. Or forgetting I had that t-square out and left it on the tablesaw. Sometimes it is benign forgetfulness…sometimes I have to leave right then. But I’ll try harder if you will.
Here’s wishing for a more collaborative environment in 2017!
