Vcc
An electronics designation that refers to voltage from a power supply connected to the “collector” terminal of a bipolar transistor. In an NPN bipolar (BJT) transistor, it would be +Vcc, while in a PNP transistor, it would be -Vcc.
Double letters (cc) refer to power supply voltages
Single letters refer to the voltage relative to ground; for example, Vc is the “collector” voltage relative to ground. Two different letters indicate the voltage between two terminals; for example: Vbe is the “base” to “emitter” voltage drop, while Vce is the “collector” to “emitter” voltage.
source pc magazine
So then VCC is a recursive circuit of voltage collector to collector.
