Yeah, gave James my two cents on it. At the price point he is looking, the Fargo we use does fit his bill.
Warnings from things I’ve learned.
Ink refills are a bit of a scam as the bulk pricing tends to be higher than buying single cartridges.
The cartridge tape can break while printing, this is an easy fix. Cut the tape square and tape it back together. Totally works again.
Buy cards in bulk qty of 1000+ savings can be immense this way.
You don’t need to scrimp on color use. You use the same amount of the cartridge if you print the color or not.
Get to understand the advanced/print properties menu while printing. The black ink and contrast settings have a large effect on quality. You can dial in a bad print to a good one this way.
Other than that, these printers are pretty bomb proof.
