Do you know what kind of wood that is?
One fun option would be cut that sucker in half (by the width) and make 2 matching end tables. You’d need to cut it, then joint each piece flat on one side, then plane them on the other side. Next would be resin filling the cracks which would really make it pop (glow in the dark powders or metallic powders in the resin for a wow factor). Finally, turn some legs for each one and finish it up (alternatively you could weld some pipe into legs, or buy premade table legs).
That should only take you a couple of weeks in your spare time.
