In VCarve Pro, if I try to edit an end mill and change its feed rate, it reverts back to its original value after I close the Toolpaths window and reopen it.
How can I make that value stick so I can experiment with different speeds?
You can change it in the tool path or in a custom library, but not in the default DMS library.
Ah, thanks. I will try that.
