Thermosiphoning - STRUCTURES AS POTENTIAL ENERGY.
Raise water up using existing tech , solar water heaters ,
dropping the water , activating an electric generator , hydro generators.
then raising it again …
Example -
Windmill poll will be fitted with simple passive evacuated tube.
all around the base , placed vertically.
so the wind mills has a generator for wind,and one more generator at the bottom,
to capture the hydro thermo siphon.
The mill would produce a lot more overall, during the day. on existing infrastructure.
on a smaller scale we could provide a working attachment to an
existing solar water heater system.
Inserting the right generator at the right spot.
letting the system pump the water / weight energy all day ,
still maintaining the solar water heater intended use .
Small devices could be made to electrify
gravity sourced generators , lights ,phones…
City water towers , already designed to hold a body of water.
could also be used to raise water and drop it ,all day.
Parking lots street lights, don’t need to sit idle all day.
We could do proof of concept , calculate loads …
They even got top of pipe fittings that increase downfall,
siphonic roof drain .
lucid energy makes inline hydro generators …
All is here, we just got put it together …
we could ,any suggestions ?
best wishs ,jp
