Anybody know of an idea / source for a 5-50 gallon high pressure / high temperature pressure vessel? I’m looking for something capable of accumulating “a little” industrial process steam in. Ok, a bunch of steam.
Generally, it needs to be capable of withstanding pressure between 1000-1500 psi and temps around the 500-1000 deg F. range.
I’ve seen a few scientific reactor vessels in the .1-1L range, but can’t find anything readily made / spec’d in what I will refer to as “pilot” size (think big-ass water heater or shop compressor size). I’m thinking it’s something sourced from a boilermaker, as they’re in the same ASME code.
I’m all out of google search terms so I figured I’d throw this one out here for all the engineering-minded insomniacs like me. Cost is not a consideration right now. Please and thank you!
Jeff
