I have a slow leak around the rim of my tire where it meets the chrome wheel, on the outer-facing side.
When they put the tire underwater at Discount Tire, I could see very tiny bubbles coming out intermittently from between the metal of the wheel and the rubber of the tire. As things stand now, I have to re-inflate my tire from 20 PSI to normal pressure once a week. They tell me that this kind of thing can happen with chromed wheels as they age. (I bought the car with chromed wheels; I didn’t ask for this kind of problem!)
Is there a rubber compound or silicone adhesive that could be applied to “plug” or seal the seam where the leak occurs? One person recommended trying Fix-A-Flat, but that doesn’t seem like a good permanent solution to a leak that small. The air pressure of the leak probably isn’t strong enough to move the Fix-A-Flat compound to the problem area. I figure that if I were to superglue/adhere/rubberize the tire to the rim after deflating the tire first, that might work, but then how do you replace the tire in the future when it’s locked to the wheel(?); and it doesn’t fix the condition that’s causing the leak.
So . . . since Discount Tire doesn’t fix this kind of problem, how would one go about finding someone who does? Any specific recommendations of people with the skill set and tools to remedy my problem? And what is the remedy?
