HOW TO ETCH AND LASER CUT ON WOOD in one art piece
Hello,
I need to do a project which requires laser cutting along with etching in one art pc. Can someone show me how to do that? Let me know and i will show up to learn this technique. Truly appreciate it.
Aysha
Have you taken laser basics? What sort of files do you have? You need a vector file to cut and either a vector or raster to etch.
I personally set the different steps as different files and load them one at a time. You can sort their order on the tree on the right and toggle between etch and cut. Typically etching is done first, then cuts.
Tonight’s Inkscape class (7:30pm) is designed to help students prep files for the laser. If your question is not covered directly, we can talk about it after.
Thank you so much! will look into it and get back if I need further help
Regards,
Aysha
Yes, i took laser basic…ok…will follow what you are saying and if i have further questions…will reach out. Thanks so much
Aysha
