I’d like to cut a design into steel using the plasma cutter and then curve the steel that I cut. Looking at a 6 inch by 12 inch design with a 23 degree Angle Subtended by Arc.
PlasmaCAM training suggest 1/8 minimum thickness of steel. Slip roller is about half of that for max thickness so I don’t think I can use both and must use Plasma for design. Any suggestions on how to curve the steel after I cut it?
