Dusting off this old thread, as it is still relevant to me right now. I have a whole lot more footage detailing what happened with the Mazda. I don’t have time to clean it an display it right now, but I will post it for all to see.
But here are descriptive results, and they are interesting ideed:
*Upon reassembly, I had to fix numerous leaks before I could run the vehicle for any span of time. Of particular concern was an old leak around the oil filter assembly. Try as I did, I simply was unable to seal this with the new felpro gasket I bought from Oreilly’s (I tried 2 of them). Ultimately, I bought a roll of thick gasket paper from Oreilly’s for about $15. I took one of the gaskets, placed it on a piece of the thick gasket paper, and cut out a thick gasket using exacto knife. This stopped all leaking immediately upon installation.
*The engine sounded GREAT, just like a brand new Mazda off the line in Japan, when I finally was able to start it. It smelled all sorts of funny and blew off various shades of smoke initially, as I figure it had all sorts of grime I had smudged on the headers, and anything in those cylinders got cooked. But the smoke stopped after a bit, making me feel comfortable for a test drive.
*The transmission did not want to shift at first. I have to fiddle with cabling before it started operating properly. But once I got this worked out, the transmission that sat on a palate for weeks covered in rust and slime now performs flawlessly. It has new fluid and filter, and now connects to a new radiator. The transmission shifts smoothly and solidly, and exhibits no symptom of any sort of trouble now. It runs as I would expect for a new car. What a relief!
*I had problems cooling the engine initially. After trying many different things, I got the fluid temp to level out at thermostat trip point. Once I saw this, I took the car around the block. It overheated. I replaced a bunch of hoses to make sure I had good flow. Ensured no kinks in any hose anywhere. Still, overheats upon 1/4 drive, every time. I finally decided that problem could be corrosion blocking radiator since car sat up in its history. Installed new radiator. This fixed all overheating problems. Then jI had a problem where the transmission fluid radiator fitting leaked. I had to construct one from parts from Home Depot. After about 10 tightening events, I finally patched that leak. Cheap radiator from Ebay=good radiator, lousy transmission fluid fitting.
*I drove car for 300-400 miles. It did OK, engine sounds great, however I noticed that the idle hunts. It ranges from 700-1100 RPM. I fiddled with sensors, and watched OBD scanner a bunch, but could not seem to solve this one. But I got my best clue when I noticed after driving some 5 miles that when I disengaged from drive to park, the exhaust would let out moderate to mild amount of white smoke. Then it occurred to me that probably my head gaskets are leaking. I surmised that it probably did not seat properly, and all the overheating at first due to radiator problems did not help. But most importantly, I did not do a great job resurfacing the heads. There was material remaining on them when I put in new head gaskets. I watched a video of man who makes his money resurfacing heads using block and sandpaper, and then he preaches as part of his lesson. My heads looked nothing like what his did when he was finished.
Then I read multiple articles concerning head flatness and seating of head gaskets. They pointed out that so much as a single overheating event is catastrophic especially for aluminum heads and block with double steel gaskets. Hmmmm.
The most common failure mode is hot gasses from cylinders getting into the coolant. Heads MUST be resurfaced to perfection prior to installing new head gasket. I did not come close to doing this. In my case, we expect that the failure mode for previous engine was that fluid got into cylinder, hydrolock, then bent rod upon running. The point of wekness where the coolant/water entered the cylinder is probably not fixed.
Now I have not bent a rod in the new engine. I ran it some, and it never sat up allowing a lot of fluid into the cylinder. However, I can see that it is not sealing well, so I have taken things apart again, at home this time, and am working to get heads resurfaced right now. I will get videos posted soon.
Thank you to all who contributed their time and help pointing me in the right direction. I am paying for my sin of not listening by having to take the time to remove the heads a second time. They will be flat as all get out, perfectly clean and resurfaced when I reinstall this time. I may be wrong, but I bet this fixes the idle hunt as well. I think hot gasses escaping the cylinders cant be a good thing for stable idling…
