Here is a good article on building a cheap paint booth. I built one similar to this, but built in panels that I can easily break down and store flat.
That’s kinda what I did for my temporary one with a pop-up, tarp and conduit. It was also in 40-50 degree weather when I did it.
Input heater to get it into the 70’s.
I modified mine a bit by building a 2x4 frame that hooks in to the frame to hold the fan in position. I also cut the plastic in panels for each side and stapled the edges and then duct taped each seam. I used 7 mil plastic and it fits over it like a couch cover. Easy on and easy off. I think once this plastic wears out, I’ll probably remake with tarp material for longer lasting. Flooring I use 3 mil plastic that I throwaway after heavy use. I added the taped zippers, but it kind of a hassle so I don’t use them very much.
