The Hobart is in my possession, we talked about someone testing it on 240vac and somehow I got tagged. Boy is that thing heavy. I might have time to play with it tomorrow, more likely mid week before I bring it back. The symptom I saw last time we used it in a mig class was a very inconsistent arc, sometimes worked fine, then would seem too low volts, then blow a hole in the weld which would have meant too high voltage.
Randy
Thanks for taking the time to work on it!
So you didn’t Bogart the Hobart!
