Getting close to having the Hobart mig welder working again…
It was missing the spool holder, new one in place now.
Someone had apparently used it with fluxcore and didn’t have a tip so ran it anyway and the arcing burned up the threads so you couldn’t screw in an .035 tip.
Liner was rusty, we have a new one to install today.
The contact block where the machine end of the gun plugs in was pitted from electrical arcing due to the engaging thumbscrew being loose, there was enough pitting that the orings wouldn’t seal so most of the shielding gas leaked out. Talked to Hobart and the block costs $70 but is obsolete so can’t be purchased. Charles and I bored out the pitting in the mounting block but that resulted in a diameter too large to fit any standard orings. We have a set of reamers, I made a new block and used an oring calculator to find a metric oring that would fit between the brass gun end and one of the hole sizes I could ream, Bob helped me setup the reamer yesterday, first time either of us had used one. O-rings should arrive this morning.
So I’m planning on putting it back together after lunch today. I don’t think I need help but if anyone is interested in participating and will be there anyway let me know. I’m guessing 30 minutes max. I’ll work around your schedule otherwise probably start about 1.
We did some test welds a few weeks ago after getting the spool holder and borrowing a tip from my Miller Passport and it worked fine.
I think there is too much idle time and not enough welding time during mig classes so want to have both mig welders working and may drag my passport in if I can get a power cord made to plug into the 3phase grinder outlet or if we get another electrical drop near the welders.
-Randy
