Its got to go on a Pi 2 B that is running Windows 10 IoT
Is there anyone that could help me get these set up? If so, how much would it cost?
Here is the use case in case anyone is curious:
The device is used only occasionally, it spends days unplugged. When it is plugged back in it often will not have an internet connection. This causes a problem because the Pi still thinks it was the date it was last powered on since it can’t reset it’s system date over the network. This causes all our data to be recorded with the wrong date time stamp.
We are hoping having the external clock with battery will solve the issue.
Reading a serial device like this RTC is trivial in Windows 10 IoT.
Open the port, send your command, read the response. Literally just a few lines of code.
Edit to add: I’m not sure if you’re looking to set the system time or if your application needs to just read the time from the clock. If the latter, this is trivial.
Setting the system time is not something I’ve done in Windows 10 IoT, nor have I set up an RTC that the OS is automatically aware of.
Yeah, I’m sure it’s not a big deal, but apparently taking that data and setting the time requires a powershell command according to that Stack Exchange thread due to a lack of API’s?
I’ve literally never heard of “Windows 10 IoT” before this thread, but I did a lot of Windows programming a long time ago. These days my life is all in containers.
This is an I2C device, while I doubt it’s difficult it’s probably a bit more convoluted than a UART.
The TX/RX pins on the board are simply bringing the rPI uart up so the user can access it since this board covers them up. They’re not connected to the RTC.
Never actually seen anyone using Windows 10 IOT before. Linux is a bit too much abstraction for me, I imagine windows is much worse.
In the sense that I2C is a TTL level serial interface, yes, but it’s quite distinct from UART, which is what Linux and Windows refer to as a Serial port.
The schematic on amazon and DS1307 datasheet clearly show this…
You’re right. The fact that it’s also connected to the (async) serial TX and RX pins on the Pi - and the unconventional labeling of the pins on the clock board - threw me. I didn’t look up the clock chip.
In any case, reading it is easy from within an application on IoT Core.
I appreciate all the help, most of the documentation above may as well be written in Klingon as far as my developer skills go. I’m a career ux and front end guy. I’d be lost without all your input.
I got a pm from someone who is helping me.
As to the question of why windows 10… It was originally running on Linux and working for it’s original requirements. When the prototype got advanced to development the developer at my office inexplicably rewrote the whole thing in c# on windows 10… I had no idea until I got it back to qc it. That dev no longer works for the company.
That said, this bug is a problem with how we are trying to use the hardware not the software. I would have had to fix it either way, but as far as I can tell from what you have all said above, with Linux adding the clock would have been a little more straight forward.
While I don’t understand much of this stuff I do find it terribly interesting. That’s why I was working with Raffi to try and have his committee do a hackathon. Perhaps when we reopen we should revive that idea.
Windows 10 IoT Core was actually pretty cool. But they gave up on it and stopped development. Very easy to use and basically no relationship to Windows as we know it.
Another company called GHI Electronics picked it up and are still adding features.
Every project I worked on that was to be deployed with MS/Windows tools ended up being screwed by Microsoft abandoning the tools.
Example: Widows SmartCards, they had the best solution to storing fairly decent datasets on the card 16-24kb. As soon as we were ready to deploy for offshore training tracking, they stopped licensing the manufacturers who made the cards. It was buy 1 million cards or nothing.
Shlumberger jumped in and saved the project even though it was for a competing oil company. They made good where Microsoft was no longer interested. Microsoft has a history of leaving a space if the market does not grow at the pace they want. It’s like they have developers with nothing to do and they have them develop a new SDK to keep them busy. Once complete they have six months to get returns all the while dragging the market around.
A Nissan project I worked on was burned by this. They signed a big deal to integrate Cortana into their cars. Then a year before launch they killed Cortana. BMW was part of the deal too but they saw it coming and jumped ship to Amazon auto.
I worked at Reflect. I had to fix the appliance app whenever it broke
Did the PC the PlasmaCAM is connected to come from you? It has a Reflect Player install log on it that has been driving me crazy trying to figure out how it found a way to still haunt me.
Ha, yeah integer donated a bunch of hardware when we downsized our office. The computer running the signs in the lobby also had the player on it. I think I’ve wiped it, but you never really know.
