I have some 1.5" tubes that need to be cut down to shorter sizes and have holes drilled into them. The cuts/drilled holes needs to be really clean and accurate.
I don’t trust myself…
I’m not sure we have anything for cutting composites with a saw/mill, specifically the correct blade. Same for drilling - drilling composites use specific drill types becuase it dulls them so fast.
How thin is the wall? For drilling, if you got the appropriate drill the Bridgeport could locate properly, but if thin wall clamping force might distort tube circularity unless fairly thick/stiff.
What’s quantity? Several not much of an issue, but more than that is since you can only use a HEPA vacuum for clean up of dust safely.
