So I’m wanting to make a wonky lighting fixture using LED flame bulbs, but removing the edison connector and rigging them up to a single plug in power source. I did find a stack overflow with a similar question, but wanted to check with y’all to see if there’s other considerations I should make. Link to said stackoverflow here: automotive - I'm trying to use 3v LEDs in a 12V circuit, in my car - Electrical Engineering Stack Exchange
These are flexible boards with a grid of LEDs on them, and the only thing I’m cutting out is the 240v to 3v bit. I’ve seen a single “bulb” converted to run off batteries, but given that this is a bit different, I just wanted a little advice.
