I have purchased a 700x500 ebay/chinese 100w laser running ruida controller and rdworks. I have a problem with the x-axis and I have tried many things to fix it over the last couple of weeks and cannot get it solved.
If you are a cnc / laser guru I will pay you $100/hr for days work if you will come to Coppell (15min from Makerspace) to help me fix my machine. I work during the week so we would need to work on it on weekends.
While appreciated, I’m not looking for free advice - I really want to pay someone who knows what they are doing to solve this so I can use this machine asap.
Here are details on my problem:
I can cut a 100mm square block on the left side of the machine which measures with a digital caliber perfectly, but the same 100mm square on the right side of the bed will measure 99.5mm on x-axis. Y Axis is perfect in all corners. The machine is consistent. I can do the same cut over and over and it repeats exactly the same. Makes me assume the stepper isn’t skipping.
Things I have checked / verified:
- Mirrors aligned well and step length calibrate in top / left corner - machine is cutting material very well
- Machine is square - verified by cutting large square and checking with large square
- Rails are tight and very smooth - verified by removing belt and sliding head
- Problem is isolated to the X axis. Y axis cuts perfectly 100mm on all corners.
- I have replaced the X axis stepper, pulley, and driver with a 2 phase 1.2degree motor - no improvement
- I have replaced the X axis belt - and tried loosening and tightening
- I have slowed the machine way down.
See Attached: The step loss is linear across the bed it appears. To eliminate Y axis completely and demonstrate problem, I have create dots across the x-axis every 10mm. As you can see in attached, on left side of bed 10 dots = 100.03mm. But as you move across X-axis, 10 dots becomes 99.58mm in the center of the bed and 99.34 on right side of bed.
