I agree with Chris, I think a desktop scanner that has a fixed platform and even mounting it to an enclosure would prevent anyone actually handling it. But it will greatly limit the use for a 3D scanner.
The software workflow I think is the single important thing. The nextengine had great scanning capabilities but it was painful to use the software and stitch scans together. We also need something that is capable with the Dell workstations we already have (they might need maxed out RAM and graphics upgrades)
Sorry, but I am not going to be able to make tonight’s meeting.
They’re letting us drive our cars on the big track at Dallas Motor Speedway during the GoodGuys car show and that’s a life experience I just gotta have.
I can second this scanner. My son used one in production for a company that was making custom prints. His feedback says it was great while using setup with the turntable but hard to get good results handheld on larger objects.
EDIT: We probably need something that can be setup and not moved around. Lest we get another dropped scanner with broken ports.
After reviewing and discussing numerous scanners, these are the scanners we decided on. Not sure yet if we’ll be acquiring both simultaneously or just one to start.
Sorry I couldn’t make it, I was also at a race last weekend. It must have been unofficial racetrack day. Those both seem like good options for small objects. What’s the thought process on getting two different ones?
I generally see the Pop being used for larger and/or living things (even faces) that would benefit more from faster capture than higher resolution. The Pop’s price point also makes it ideal for hand-held scanning over the Einscan, as the drop likelihood for both is high.
I could see the Einscan being preferred when detail is important for smaller things that fit on the turntable. From the demo videos, the large format mode of the Einscan doesn’t appear to do live mesh alignment between frames, and the sensor is intended to remain in a static position.
Overall, I think it makes sense to see how well the Pop meets our needs before considering the additional expense of the Einscan.
