Heavy duty tables!
Wow! Check them out in the illegal storage section of Suite 102…
I wonder how much weight they will hold? Anyone care to set up a betting pool?
Such wonderful cross-bracing!
I’m reminded of the Allen tables, albeit seemingly without any of their strengths.
Are we betting in Kilos or lbs?
Pounds? Troy or Avoirdupois?
Tables that big, go for Stones.
That will keep the test weight a manageability small figure.
brick sizes seem more consistent than stone sizes.
“cough”… a stone is a British measure of weight… 14 lbs…
Yeah I know, but with all the random phrases being tossed about and the breathtaking engineering on the tabletops, seemed like longevity would be questionable under ANY circumstances.
So we don’t know where these came from ?
How thick’s the sheathing?
I’m betting it’ll hold two fitty.
Maybe… 1/2 inch…
It’s not getting obtuse until one breaks out the FFF System of measurements:
Unit Abbreviation Dimension SI unit Imperial unit
furlong fur length 201.168 m 220 yards
firkin fir mass 40.8233133 kg 90 lb[a]
fortnight ftn time 1,209,600 s 14 days
The speed of light is 1.8026×1012 furlongs per fortnight (1.8026 megafurlongs per microfortnight).
Think about that - mega unit per micro unit - I haven’t seen that kind of deliberate obtuseness since I saw some Euro electrical switchgear labelled as 0.1kV … or a giant filter cap labelled confoundingly as 100000 MFD (where the “M” was presumably micro - conventionally expressed as μ - as opposed to mega normally expressed as M but the whole thing should have been 100 mFD so as to not break engineering notation … but the milli-farad isn’t commonly used)
