Heat press is down (FIXED - No longer down)
I figured a sign on the machine would be enough, but no.
The clamshell heatpress keeps blowing its fuse, something is wrong with it.
Please do not use it, it is out of order until further notice.
In the meantime, we have the smaller press in the cupboard under the vacuum (@CaryF300 can confirm)
Again, please do NOT use the clamshell!!
Thanks
The heat press has been fixed and tested. It should be good to go!
Thanks for being patient, and thank you @Sk8nmike for the help!
What was the problem with it?
A loose connection inside the unit
