I’ll be there Tuesday and Wednesday … more for moral support (and money for the lights). But you guys are the important ones, so whatever works for you.
I’ll be playing with the Cold Cut Saw, plan on leveling and getting set-up the feed table so it can be bolted up to it when finished with coolant testing that will be ready. Also if Chuck G says I can raid the material stash in Metal Shop I’ll get the Material holding bin welded up that will go next to it.
After that, then it’ll be putting new wheels on granite table. Bob and I figured out how to safely get the granite stone out safely so table can be flipped. Calculated weight of stone is about 650~700lbs. Will use the gantry to lift out and set on pallet then put back. If @Brandon_Green has scale by then we’ll know what the weight actually is.
