So, this may be a dumb question, but in my current project, there are 3 different currents- 5V, 12V and 24V, all running separate things. Is there any reason I can’t tie the grounds together in these? It makes it a lot easier to wire, but I am wondering if there is a reason people don’t do that more.
For instance, I have a 5V voltage regulator, which has 12V and Gnd IN and 5 V and Gnd OUT, I take that ground and just connect it back to the 12V GND, so effectively theres just one wire coming out. I have the logic circuit wired up to the same ground as all three nets. There is a 12V supply and 24V supply independent of each other, and that 5V regulator for the logic circuit.
Could there be any damage? Especially to the logic circuits.
