I just finished a heavy duty steel bracket, that needs corrosion protection. Does anyone have a recommended shop to galvanize one off parts? The whole bracket was cut out of 1 square foot of 3/8 steel plate.
If this is not a critical dimension part you may want to consider hot dip galvanizing rather than a conformal coating. Most hot dip companies do both. The largest in the Dallas area is AZZ Galvanizing - Hurst (http://www.azz.com/) . Another is K-T Galvanzing Co. in Johnson County, Texas (https://www.ktgalvanizing.com/). Your project is probably too small for them to want to bid on it, so be prepared. If it were me doing this I would show up with the part anyway and talk to one of the office people. They may/may not help you but they can probably recommend a smaller shop that does one of work. I have not done business with either company.
Best,
Jim
You may consider powder coating as an option. There’s a lot of shops that will do small powder coating jobs.
