Yesterday I imported an SVG genertated from Inkscape and had some weird behavior. The cutouts from A and R appeared on their own to the left of the letters. I opened the svg in Adobe Illustrator and saved it as an ai file. When I imported the new file, everything was good. Only took 2 hours of wracking my brain to try that
Just curious - did you notice if the teflon cutting strip has been replaced yet on the cutter?
Same issue with Capital letter I (eye). Inkscape can’t generate something that can be cut. Putting into Illustrator and saving to .ai fixes that problem also.
No I didn’t notice. Sorry.
@Team_Creative_Arts can you find out about the Teflon strip that needs replacing ?
99% sure that was solved with the Titan. Was the STRANGEST bug.
