Fusion 360 exporting stl as wrong size
I am trying to print a few designs I made in fusion 360 but when I open them in cura they are way too small. I use the “make” tab and the “save as stl” under the bosy but have the same result. Does anyone know what is wrong?
Its probably MM vs INCH
Change the setting on your branch (on the left), and export again
^^^ Ding Ding ^^^ This is the most likely issue.
If your model was designed in Millimeter Units and you import it in a system that recognizes the units as Inches, you have effectively converted your model to 1/25th scale.
KissSlicer has a conversion tool in the upper right to switch between Metric and Imperial.
like others have mentioned sometimes you can be designing in MM and itll export to inches
or youll be designing in inches and exporting to MM
