Has the group ever discussed purchasing a fume scrubber/Fume Extractor for the lasers? We cut a lot of nasty stuff that everyone ends up breathing even with our current exhaust system. Also, this all gets pushed out into the environment and we may be breaking a few EPA industrial pollution laws.
I have a buddy that is buying the fume extractor below for their shop’s laser and was hoping to get some feedback on it.
No I am talking the laser. I have never been in the building when the plasma cutter was in operation. But I have seen smoke coming out of the laser cutter when it was running without the venting being turned on.
I looked into it last year to see if it’s viable to run inside without sucking a/c air out and just dropping the air back inside, cost is about 6k per laser and requires running cost of replacement activated charcoal.
I also heard it does not completely remove the smell of burning arcylic.
I ended up with the conclusion 6k is a lot of electricity and still would have to deal with the smell so venting outside won out.
At this time I do not know of any regulatory requirement as well as I have never seen one in use with the exception of a place in Philly that was not able to put holes in the bldg
@MilTech996 question, what do you think in particular that we are venting out? Also, you mentioned EPA what do you think we are violating? Just wondering if you have some information I don’t know or if you are hypothesizing?
At the old DMS location we had an interlock that prevented the tube from firing unless the fans were running. Seems like a better solution. No fan => no cut => turning the fan on.
At one point we did (Alyssa’s laser perhaps?) because the head would move but that laser would not fire w/out the fan on. May have been before you joined, @william_petefish.
The real question is can the laser committee modify the current setup so that the exhaust fan always comes on automatically when either of the lasers is operating?
Or are we ok with it being a separate manual step and relying on every user every single time checking that it is on to prevent hazardous fumes from filling the workshop? In the same way we depend on every user every time to not burn the building down.
I’m not sure about the particular brand of laser at DMS, but my Universal Laser has an option in the software driver that is a user selectable option to make sure the air is on. I have it set to not allow the laser to fire unless it gets a positive pressure of 10 PSI from my compressor.
