It hasn’t separated from the 2nd stage yet, but the big scary rocket-powered ascent stage is over!
https://www.amsat.org/fox-1cliff-launch-your-help-is-needed/ they would like as much telemetry data as possible. I doubt my current antenna system is up to it, but I’ll try and get my rtlsdr hooked up to something . Can’t hurt to try, they said they plan on leaving it beaconing for at least the first 24 hours.
What frequencies?
145.920MHz is the downlink the uplink will be (67 Hz CTCSS 435.300 MHz &
1267.300 MHz depending on which ground control has it switched to.
