I printed an airplane on the form 2 with the clear resin. I used the wash and cure stations after the print. When I got home I put it in a uv light for a long time. When I went to remove the supports I used flush cutters but when I cut the supports off the tail, wings, and landing gear broke off. Is it normal for it to be so brittle. Could I have cured it too long?
It’s a high probability. I’ve found overcuring can either make it too brittle or in some cases change the color.
How long did you cure the piece for?
I did the 15 in the form cure than around 30 at home
