About that newspaper – that is not a normal supply for the Fired Arts area. I started grabbing a little here and there so that we could glaze on the wedging table without the potential for getting glaze mixed into the clay. If you’re encouraging every neophyte to use newspaper instead of simply wiping the table with a sponge, you’re going to need to be the one that makes sure we’ve got enough newspaper for both uses.
And metal shop thanks you for that.
Not a problem, I have already bolstered the supply on the shelf and will continue to keep an eye on it.
Re newspaper supply
At a place I used to do pottery, they kept a stack under a table, and folks that still take print newspapers would bring in some from time to time if it looked low.
Had the same thing with a box of light plastic covering like dry-cleaner bags and grocery sacks for covering things to dry slow. Replenished as people remembered to bring things in.
It worked well and it was easy once folks knew about it (get the word out), plus good recycling.
